[GRASS-user] r.proj's "use different location" error while
working in different dbases
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Jul 5 07:24:13 EDT 2009
Nikos:
> > I have "wgs84" locations in different dbases, for example:
> > "/grassdb/ellas/wgs84" and "/grassdb/global/wgs84".
> > I want to "r.proj" something from "ellas" to "global" dbase
> > and I get the following error:
> > ERROR: You have to use a different location for input than
> > the current
> > This is a bug, ins't it? I suppose the "dbase=" parameter
> > is not checked at all in this case (?).
Hamish:
> yes, it appears so.
> r.proj(.seg) has the following check:
> if (strcmp(inlocation->answer, G_location()) == 0)
> G_fatal_error(_("You have to use a different location for input than the current"));
> maybe it should assemble indbase->answer/inlocation->answer
> and test that against G_location_path(). ? then dirsep hell?
> please file a bug
Done: http://trac.osgeo.org/grass/ticket/675
Alternative solution with respect to the specific example here: allow
g.copy to copy data from another dbase/location to the current dbase in
a location with identical name and projection definition of course (?).
Nikos
