[GRASS-user] Re: link to datasets from other locations?
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sun Jul 5 07:39:39 EDT 2009
Tim,
please keep person's names when you reply. It's easier to follow-up :-).
Nikos:
> > moving from one location to another location (which usually is/should be
> > of another projection) is "safely" done with v.proj. Why use another
> > command for that?
Tim M:
> Then v.proj should support:
> * -r flag for importing only the current region extend
Read also discussion at trac [1]
> * -ship_project flag if source & target locations have the same
> projection, can also be detected automatically.
Read my post (and bug-ticket) about a similar case [2][3]
> * -d: delete source dataset after successful reprojection
I have the feeling that is not safe (!).
> The same should apply for r.proj
> >>> if you want to mix things you must use multiple mapsets from the
> >>> same location with @othermapset.
Tim:
> Image the following use case: You have project location.
> Then you would like to test out some new processing workflows or
> developed a new methodology.
> In order not to pollute the project location with a lot of test rasters,
> you start a new location to do the testing. Maybe I am
> misunderstanding the concept of mapsets.
Maybe(?). Why not create a test-mapset/test-location within the same
dbase?
> And that the develpers meat mapsets to provide this kind of functionality.
> So will removing a mapset also automatically remove all datasets that
> belong to it?
No-way! Only the datasets that the mapset contains.
Tim:
> >> Imagine a shared location with common data such as world borders or GSHHS.
> >> It would not be space efficient to import such large data into every new
> >> project. Rather sharing the common location when needed.
Nikos:
> > I find that your question/thought makes sense. I faced myself this in
> > the past. I decided to build a location called ellas (=greece) where I
> > put everything that covers/has to do with greece. From there I "pull" it
> > to wherever required, do what has to be done and erase if not required
> > anymore.
Tim:
> What command do you use to "pull"?
> v.proj & r.proj?
Pull from a mapset to another mapset within a location is actually
"g.copy".
Pull from a location to another location is "v.proj"/"r.proj". because
you (usually) need to re-project.
Nikos
[1] http://trac.osgeo.org/grass/ticket/328
[2]
http://n2.nabble.com/r.proj's-"use-different-location"-error-while-working-in-different-dbases-td3206919.html#a3206919
[3] http://trac.osgeo.org/grass/ticket/675
