[GRASS-user] r.terraflow error for ASTER DEM.
Markus Neteler neteler at osgeo.org
Sun Jul 5 09:53:19 EDT 2009
On Sun, Jul 5, 2009 at 3:35 PM, Glynn Clements<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> 3. The default value of /var/tmp is inappropriate for Windows. It
>> >> should probably use the TMP or TEMP environment variables. There
>> >> probably won't be a specific directory which will be writable by all
>> >> users.
>> Ok, but the current default fails for sure. Personally I still think that
>> the current mapset is a more appropriate default.
>> We should change on Windows at least to a "more likely" directory.
>> Which?
>        G_convert_dirseps_from_host(G_store(getenv("TEMP")));
done in
6.4.0svn: http://trac.osgeo.org/grass/changeset/38256
6.5.svn:  http://trac.osgeo.org/grass/changeset/38254
7.svn: http://trac.osgeo.org/grass/changeset/38253
          http://trac.osgeo.org/grass/changeset/38255
Windows testing welcome.
Markus
