[GRASS-user] Mac OS X compilation and addons question (how to add
on addons)
stephen sefick
ssefick at gmail.com
Wed Jul 8 10:18:09 EDT 2009
Mac OS X 10.5.7
Downloaded and installed dependencies from:
http://www.kyngchaos.com/software:frameworks
cd into the source directory
run in the terminal as to the example in the macosx folder of the source:
./configure --with-freetype
--with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
/Library/Frameworks/FreeType.framework/unix/include"
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
--with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
--with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
--without-postgres --without-mysql --with-odbc --with-sqlite
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
--with-cxx --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
/Library/Frameworks/Tk.framework/Headers
/Library/Frameworks/Tk.framework/PrivateHeaders"
--with-tcltk-libs=/usr/local/lib --with-x --without-motif
--without-glw --with-opengl=aqua --without-readline
--prefix=/Applications --enable-macosx-app
>make
end of make output:
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: Wed Jul 8 09:03:28 CDT 2009
Errors in:
No errors detected.
>sudo make install
installs fine
Now I would like to add some addon packages specifically v.strahler.
I can not figure this one out.
I have
svn checkout https://.../ grass-addons
which checks out the source to a folder in
/User/sefick/grass-addons
I am not sure if I need to compile the sources and then recompile
grass or use some sort of method hinted at in this post:
http://n2.nabble.com/need-help-with-mac-os-x-installation-td1879293i20.html#a1879310
thanks for all of your help,
Stephen Sefick
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
-K. Mullis
