[GRASS-user] Mac OS X compilation and addons question (how to add
on addons)
William Kyngesburye
woklist at kyngchaos.com
Wed Jul 8 11:17:56 EDT 2009
The addon compilation setup for OSX is kindof in limbo right now. I
think it still works. First make install GRASS. Then look at /
Library/GRASS/6.4/modbuild/ReadMe.rtf.
There is a platform-neutral make setup that is also installed now, but
I'm not sure about the state of it in 6.4 or 6.5.
In 7.0/trunk there is a new g.extension module that (I think) should
be replacing GEM and work for OSX's needs.
On Jul 8, 2009, at 9:18 AM, stephen sefick wrote:
> Mac OS X 10.5.7
> Downloaded and installed dependencies from:
> http://www.kyngchaos.com/software:frameworks
> cd into the source directory
> run in the terminal as to the example in the macosx folder of the
> source:
> ./configure --with-freetype
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/
> unix/include/freetype2
> /Library/Frameworks/FreeType.framework/unix/include"
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/
> unix/include
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/
> include
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/
> include
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/
> include
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --without-postgres --without-mysql --with-odbc --with-sqlite
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/
> include
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
> --with-cxx --with-tcltk-includes="/Library/Frameworks/Tcl.framework/
> Headers
> /Library/Frameworks/Tk.framework/Headers
> /Library/Frameworks/Tk.framework/PrivateHeaders"
> --with-tcltk-libs=/usr/local/lib --with-x --without-motif
> --without-glw --with-opengl=aqua --without-readline
> --prefix=/Applications --enable-macosx-app
>> make
> end of make output:
> Following modules are missing the 'description.html' file in src code:
> GRASS GIS compilation log
> Started compilation: Wed Jul 8 09:03:28 CDT 2009
> Errors in:
> No errors detected.
>> sudo make install
> installs fine
> Now I would like to add some addon packages specifically v.strahler.
> I can not figure this one out.
> I have
> svn checkout https://.../ grass-addons
> which checks out the source to a folder in
> /User/sefick/grass-addons
> I am not sure if I need to compile the sources and then recompile
> grass or use some sort of method hinted at in this post:
> http://n2.nabble.com/need-help-with-mac-os-x-installation-td1879293i20.html#a1879310
> thanks for all of your help,
> Stephen Sefick
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
