[GRASS-user] .e00 to DEM
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Jul 8 17:37:12 EDT 2009
Nikos:
> > * gdal reports:
> > Band 1 Block=20x4 Type=Int16, ColorInterp=Undefined
> > Min=0.000 Max=1371.000
> > NoData Value=-32768
> > * grass reports:
> > r.info dem250 -tr
> > min=-32687
> > max=32645
> > datatype=CELL
Did you notice that gdal's "NoData Value=-32768" != grass' "min=32645" !
= grass' "max=32645". It's not a typo of mine. Where are these values
(that grass reports) coming from?
Dylan:
> Looks like a 16bit signed integer file. I have found that in the past using
> gdal_translate and manually setting the data type and nodata value results in
> the generation of a new file that GRASS can read in without further work.
Will try.
> Also, have you tried manually setting NULL cells with
> r.null setnull=32768
Does not help unfortunately.
Nikos
