[GRASS-user] Re: Problem with wxGUI.Nviz extension andwxGUI.Vector_Digitizing_Tool
Tomas Zigo tomas.zigo at slovanet.sk
Sat Jul 11 08:43:52 EDT 2009
Martin Landa <landa.martin <at> gmail.com> writes:
> Hi,
> note that you can create a new vector map also using v.edit or v.in.ascii, e.g.
> v.edit map=Skuska1 tool=create
I am using create new vector map with v.digit for this test (It's wrong way?)
but table created with v.db.addtable for this vector map (problem with editing I
had  also with editing [add, drop, rename column] exist vector map for example
contour derived from dmt with r.contour), but when I am using v.edit to create
new vector map and create table and I am trying add column is working now
(working add, drop, rename column from wxpython ATM, cli also), but I am
updating my system before.
It is different to creating vector map with v.digit and v.edit for this tests. .
> 3) v.db.connect map=Skuska1 table=Skuska1 -o
This is not needed, v.db.addtable connects newly created table to the
vector map.
Yes, I know.
> Assuming, that 'Polana_a_okolie_1k10000_5m' is your current mapset. It
> works for me (6.4.0svn, GNU/Linux).
Yes 'Polana_a_okolie_1k10000_5m' is my current mapset.
My OS is GNU/Linux distributuon: Archlinux
GRASS version: grass-6.4.svn_src_snapshot_2009_07_04
Cpu: i686, x86-64
But now is vector editing work good (updating my system Archlinux on both
computer i686, x86-64), or this problem related with I am using v.digit to
create new vector map instead of v.edit?
Thanks Martin.
Tomas
