[GRASS-user] Help with r.to.vect
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Jul 17 07:56:25 EDT 2009
incanus wrote:
> ...I'm trying to vectorize the areas from a image map,
> and I'm a rookie with GRASS. If anyone could help me a little, it would be
> great.
Hi Andres!
Did you specify the "feature=area" parameter? E.g.:
r.to.vect in=RasterMap out=VectorMap feature=area
Also, check the manual of r.to.vect [1].
Kind regards, Nikos
[1] http://grass.osgeo.org/grass64/manuals/html64_user/r.to.vect.html
or just type "r.to.vect help" in the command line.
