[GRASS-user] Re: Earthquake PHP map - was: Re: Geocentric Datum of
Australia 1994
Hamish
hamish_b at yahoo.com
Sat Jul 18 02:10:03 EDT 2009
Hamish:
> > http://grass.itc.it/spearfish/php_grass_earthquakes.php
> > low priority wishes:
> > - how to brighten the Blue Marble colormap (RGB raster)?
> > i.landsat.rgb?
> It is running in GRASS 6.1 (yes!), so no i.landsat.rgb... I
> could rip out the relevant parts from the script and try.
ok, or from a newer version of GRASS generate a color map then
drop it over the Blue Marble map's colr/ file.
I've just tried i.landsat.rgb with the Blue Marble 2002 (no bathy),
it makes the Sahara-Gobi quite contrasty.
So i.landsat.rgb is good at adjusting pseudo-contrast. A method to
adjust pseudo-brightness is:
g.region res=1
r.mapcalc "one = 1"
g.region res=0:10
r.composite r=BlueMarble2002.red g=BlueMarble2002.green \
b=BlueMarble2002.blue out=BlueMarble2002_10min.rgb
d.shadedmap drape=BlueMarble2002_10min.rgb relief=one bright=25
Sahara-Gobi still glow too brightly, some experimentation might be
needed to find a compromise?
(tip: set resolution very coarse during trial and error for speed)
also a gee-whiz wish would be to use the Blue Marble NextGen image of
the current month instead of hardcoded May. :)
> > Richter scale is logarithmic, but bubble radius is linear classed
> > to int order of magnitude- the whoppers get hidden in the noise.
> Uhm, good point. Solutions welcome (ideally a d.vect.thematic patch,
> maybe a flag?)
I had hoped to add a new size_column= option to d.vect when I found some
time or the need became pressing, maybe it would help too.
https://trac.osgeo.org/grass/ticket/600
Hamish
