[GRASS-user] Re: Building topologically correct stream network
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Tue Jul 21 12:19:30 EDT 2009
Hi
maybe this will help:
http://gis.vsb.cz/GIS_Ostrava/GIS_Ova_2009/sbornik/Lists/Papers/060.pdf
it require another gis program but gives great results!
Jarek
Margherita Di Leo pisze:
> Hi Stephen,
> I actually am fighting against almost the same problem, so let's do it
> together :)
> I found that r.strahler.sh works well to delineate streams and correct
> topology, (I use a treshold of 1km^2, it works well but don't ask me
> why :) ), but (in my little experience) does not work to order
> streams, so I must run v.strahler after r.strahler.sh.
> I know it's a very small hint but hope this helps.
> Best
> margherita
> I have a low relief area in the costal plain of georgia that I am
> trying to produce a topologically correct stream network. There are
> many breaks in the flow accumulation grid and I would like to
> delineate the streams and "correct" the topology after r.thin and
> r.to.vect have been preformed so that I can then use v.strahler to
> order the streams. Thanks for any help and I will provide and data
> that would be helpful. thanks,
> -- Stephen Sefick Let's not spend our time and resources thinking
> about things that are so little or so large that all they really do
> for us is puff us up and make us feel like gods. We are mammals, and
> have not exhausted the annoying little problems of being mammals. -K.
> Mullis
