[GRASS-user] Building topologically correct stream network
Markus Metz
markus.metz.giswork at googlemail.com
Thu Jul 23 10:25:05 EDT 2009
Margherita Di Leo wrote:
> Hi all
> Hi Markus,
> thanks for your answer. I found that the problem is in the topology of
> the river network. I think that v.strahler produces many '0' because
> it finds many little 'circles' in the stream vector. I tried to
> produce the stream network both with r.watershed -> r.to.vect and with
> r.strahler.sh -> r.to.vect: the results obtained in both ways are very
> similar. Is there a way to eliminate these circles, not by hand ?
r.strahler.sh tries to if I understand the script right, but there must
be side effects: what were parallel streams with a ladder may be merged
into one stream.
Maybe a new module to extract both raster and vector stream networks
from any flow accumulation map would indeed be useful.
Markus M
>>> I'm sorry but the procedure that I proposed does not produce good
>>> results. In fact the ascii file produced by v.strahler has very
>>> strange orders, and also many 0 (that does not have sense in
>>> strahler order!). I think the problem is generated in finding the
>>> outlets
>> Outlet points are where stream is not null and drainage direction is
>> negative, e.g.
>> r.mapcalc "outlet_points = if(!isnull(streams) && drainage < 0,
>> streams, null())"
>> That would give you outlet points whose cell value is the stream
>> segment number leading to the outlet point.
>>> and/or confluences.
>> All nodes of the stream vector, excluding outlet points?
>> Markus M
>>> Waiting for the response of the List (please)..
>>> margherita
>>> Jarek Jasiewicz wrote:
>>>> Hi
>>>> maybe this will help:
>>>> http://gis.vsb.cz/GIS_Ostrava/GIS_Ova_2009/sbornik/Lists/Papers/060.pdf
>>>> it require another gis program but gives great results!
>>>> Jarek
>>>> Margherita Di Leo pisze:
>>>>> Hi Stephen,
>>>>> I actually am fighting against almost the same problem, so let's
>>>>> do it together :)
>>>>> I found that r.strahler.sh works well to delineate streams and
>>>>> correct topology, (I use a treshold of 1km^2, it works well but
>>>>> don't ask me why :) ), but (in my little experience) does not work
>>>>> to order streams, so I must run v.strahler after r.strahler.sh.
>>>>> I know it's a very small hint but hope this helps.
>>>>> Best
>>>>> margherita
>>>>> I have a low relief area in the costal plain of georgia that I am
>>>>> trying to produce a topologically correct stream network. There
>>>>> are many breaks in the flow accumulation grid and I would like to
>>>>> delineate the streams and "correct" the topology after r.thin and
>>>>> r.to.vect have been preformed so that I can then use v.strahler to
>>>>> order the streams. Thanks for any help and I will provide and data
>>>>> that would be helpful. thanks,
>>>>> -- Stephen Sefick Let's not spend our time and resources thinking
>>>>> about things that are so little or so large that all they really
>>>>> do for us is puff us up and make us feel like gods. We are
>>>>> mammals, and have not exhausted the annoying little problems of
>>>>> being mammals. -K. Mullis
