[GRASS-user] r.watershed crashing grass.
Markus Metz
markus.metz.giswork at googlemail.com
Sat Jul 25 03:49:01 EDT 2009
With 7201 rows x 7201 columns, the in-memory version should use at most
1.6GB of RAM. There should be no problem running it all in memory (no -m
4096) on a machine with 6GB.
Markus M
Milton Cezar Ribeiro wrote:
> Dear all,
> I am trying run a r.watershed command with one 7200x7200 DEM map.
> But after one day running, the system crash without finish the output
> generation.
> Please, see below (2 warnings before crash).
> By the way I am running grass 6.4.0 SVN (rc4?) under Msys/Vista
> on a 6Gb/64 bits machine.
> Thanks for the help,
> milton
> GRASS 6.4.0svn (newLocation):c:/Users/famiglia > g.region -p
> projection: 0 (x,y)
> zone: 0
> north: -23.99986111
> south: -26.00013889
> west: -49.00013889
> east: -46.99986111
> nsres: 0.00027778
> ewres: 0.00027778
> rows: 7201
> cols: 7201
> cells: 51854401
> GRASS 6.4.0svn > g.region rast=FabioASTGTM_S2526W04948_dem
> GRASS 6.4.0svn > r.watershed.exe -m 4096
> elevation=FabioASTGTM_S2526W04948_dem
> stream=FabioASTGTM_S2526W04948_dem_rwatershed_stream_thres0100
> threshold=100 --o
> WARNING: Subprocess failed with exit code 255
> WARNING: category information for
> [FabioASTGTM_S2526W04948_dem_rwatershed_stream_thres0100] in
> [PERMANENT] missing or invalid
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
