[GRASS-user] g.manual tries to run C:\Program Files\Internet
Exporer\iexplore (the 'L' is missing from 'Explorer')
Glynn Clements
glynn at gclements.plus.com
Sun Jul 26 12:40:30 EDT 2009
Hamish wrote:
> > rem Path to your web browser
> > rem set
> > GRASS_HTML_BROWSER=%SYSTEMDRIVE%\PROGRA~1\INTERN~1\IEXPLORE.EXE
> > I also tried changing the above statement to:
> > set GRASS_HTML_BROWSER=%PROGRAMFILES%\Internet
> > Explorer\iexplore.exe
> > but I still got the same error.
> > C:\OSGeo4W\etc\ini\grass.bat
> > Explorer\iexplore
> > I can confirm that grass.bat is executed, but it also
> > appears to be
> > overridden by grass64.bat (I can tell because the g.manual
> > error contains
> > "iexplorer.exe" rather than just "iexplore").
> fwiw, mswindows/GRASS-Installer.nsi in the source code sets
> it to iexplore.exe
Could anyone clarify which of the following are valid arguments to
GRASS_HTML_BROWSER?
1. A native filename, e.g.:
C:\GRASS\docs\html\index.html
2. A Unix-ish filename, e.g.:
C:/GRASS/docs/html/index.html
3. A file: URL, e.g.:
file:///C:/GRASS/docs/html/index.html
4. A HTTP URL, e.g.:
http://grass.osgeo.org/
It would be much easier to set GRASS_HTML_BROWSER correctly if I knew
how it's actually meant to be used.
