[GRASS-user] g.manual tries to run C:\Program Files\Internet
Exporer\iexplore (the 'L' is missing from 'Explorer')
Hamish
hamish_b at yahoo.com
Sun Jul 26 18:03:47 EDT 2009
Glynn Clements wrote:
> Could anyone clarify which of the following are valid
> arguments to GRASS_HTML_BROWSER?
> 1. A native filename, e.g.:
> C:\GRASS\docs\html\index.html
> 2. A Unix-ish filename, e.g.:
> C:/GRASS/docs/html/index.html
the above failed on ms windows, which split it into C :/ GRASS..
and didn't know the "C" rfc protocol, and then :/ as the first
part of :// etc.
changed to be:
> 3. A file: URL, e.g.:
> file:///C:/GRASS/docs/html/index.html
from gis.m AFAIR.
> 4. A HTTP URL, e.g.:
> http://grass.osgeo.org/
I assume that would work, but I believe the goal is to have help
available on the local computer as the software could often
be used on a laptop for field work where no internet access is
available.
> It would be much easier to set GRASS_HTML_BROWSER correctly
> if I knew how it's actually meant to be used.
I expect exact argument usage is dependent on the browser you
give for GRASS_HTML_BROWSER.
AFAIK g.manual is now fixed on WinGrass, we just wait for new
builds to confirm.
Hamish
