[GRASS-user] Extracting non-overlapping lines
Moritz Lennert
mlennert at club.worldonline.be
Mon Jul 27 09:22:02 EDT 2009
On 22/07/09 01:06, Dwight Needels wrote:
> Hi all,
> I have two nearly identical line vectors, and I would like to extract
> the lines that differ between the two vectors into a third vector.
> Specifically, I want to isolate the connecting lines that were generated
> by v.net operation=connect. Something like:
> [map_C = map_A NOT map_B] for line features.
> I thought I would be able to use v.overlay with operator=not, but it it
> appears to require that btype=area. It also appears that v.select allows
> only operator=overlap.
> Can someone point me in the right direction?
Unless you can try the new GEOS support Markus suggested, you can also
try via a raster approach (untested):
v.to.rast A and B
r.mapcalc C=(if(A && isnull(B)), 1, null())
r.to.vect C
You will have to adjust your region settings (g.region) in order to make
this work.
Moritz
