[GRASS-user] Re: announcement of strahler stream order analysis
Annalisa Minelli annagrass6 at gmail.com
Tue Jul 28 09:31:36 EDT 2009
I tried it just right now to see the strahler ordering and.. it works
greatly!
well done Jarek..:-)
I think I'm going to read the code because I've got to understand how did
you solved the problem of cleaning topology..
congratulations! great work!!!
Annalisa
2009/7/28 stephen sefick <ssefick at gmail.com>
> It works fine on my machine.  Mac OS X, compilied addon and compilied
> GRASS from scratch.  The strahler output also looks sensable.  I do
> have a question, though.  Say I have my own delineated streams with
> another method, but in raster format- will this still work?  And is
> there an easy way to a vector out of a raster stream network?
> Stephen Sefick
> On Tue, Jul 28, 2009 at 4:32 AM, Margherita Di Leo<diregola at gmail.com>
> wrote:
> > Hi Jarek,
> > I downloaded and compiled r.stream without problems but i'm afraid it
> does
> > not work:
> > r.stream dir=drainage at ex_20 stream=basin1 at ex_20 strahler=strahler
> > shreeve=shreve class=class
> > dirs, 3
> > streams, 4
> > Reading maps...
> > *** glibc detected *** r.stream: corrupted double-linked list:
> > 0x000000000067c2c0 ***
> > ======= Backtrace: =========
> > /lib/libc.so.6[0x7f77dfb86322]
> > /lib/libc.so.6(cfree+0x8c)[0x7f77dfb89c1c]
> > r.stream(createMaps+0x353)[0x401df3]
> > r.stream(main+0x1c1)[0x402011]
> > /lib/libc.so.6(__libc_start_main+0xf4)[0x7f77dfb301c4]
> > r.stream[0x401619]
> > ======= Memory map: ========
> > 00400000-00404000 r-xp 00000000 08:03 5955752
> > /usr/local/grass-6.5.svn/bin/r.stream
> > 00603000-00604000 rw-p 00003000 08:03 5955752
> > 00604000-41e9f000 rw-p 00604000 00:00 0 [heap]
> > 7f77d8000000-7f77d8021000 rw-p 7f77d8000000 00:00 0
> > 7f77d8021000-7f77dc000000 ---p 7f77d8021000 00:00 0
> > 7f77df700000-7f77df70d000 r-xp 00000000 08:03 4071544 /lib/libgcc_s.so.1
> > 7f77df70d000-7f77df90d000 ---p 0000d000 08:03 4071544 /lib/libgcc_s.so.1
> > 7f77df90d000-7f77df90e000 rw-p 0000d000 08:03 4071544 /lib/libgcc_s.so.1
> > 7f77df90e000-7f77df910000 r-xp 00000000 08:03 6677083 /lib/libdl-2.7.so
> > 7f77df910000-7f77dfb10000 ---p 00002000 08:03 6677083 /lib/libdl-2.7.so
> > 7f77dfb10000-7f77dfb12000 rw-p 00002000 08:03 6677083 /lib/libdl-2.7.so
> > 7f77dfb12000-7f77dfc6a000 r-xp 00000000 08:03 6677080 /lib/libc-2.7.so
> > 7f77dfc6a000-7f77dfe6a000 ---p 00158000 08:03 6677080 /lib/libc-2.7.so
> > 7f77dfe6a000-7f77dfe6d000 r--p 00158000 08:03 6677080 /lib/libc-2.7.so
> > 7f77dfe6d000-7f77dfe6f000 rw-p 0015b000 08:03 6677080 /lib/libc-2.7.so
> > 7f77dfe6f000-7f77dfe74000 rw-p 7f77dfe6f000 00:00 0
> > 7f77dfe74000-7f77dfef4000 r-xp 00000000 08:03 6677084 /lib/libm-2.7.so
> > 7f77dfef4000-7f77e00f3000 ---p 00080000 08:03 6677084 /lib/libm-2.7.so
> > 7f77e00f3000-7f77e00f5000 rw-p 0007f000 08:03 6677084 /lib/libm-2.7.so
> > 7f77e00f5000-7f77e010b000 r-xp 00000000 08:03 6490242
> > /usr/lib/libz.so.1.2.3.3
> > 7f77e010b000-7f77e030b000 ---p 00016000 08:03 6490242
> > 7f77e030b000-7f77e030c000 rw-p 00016000 08:03 6490242
> > 7f77e030c000-7f77e0314000 r-xp 00000000 08:03 984193
> > /usr/local/grass-6.5.svn/lib/libgrass_datetime.6.5.svn.so
> > 7f77e0314000-7f77e0513000 ---p 00008000 08:03 984193
> > 7f77e0513000-7f77e0514000 rw-p 00007000 08:03 984193
> > 7f77e0514000-7f77e0567000 r-xp 00000000 08:03 984236
> > /usr/local/grass-6.5.svn/lib/libgrass_gis.6.5.svn.so
> > 7f77e0567000-7f77e0766000 ---p 00053000 08:03 984236
> > 7f77e0766000-7f77e0769000 rw-p 00052000 08:03 984236
> > 7f77e0769000-7f77e0770000 rw-p 7f77e0769000 00:00 0
> > 7f77e0770000-7f77e078d000 r-xp 00000000 08:03 6676548 /lib/ld-2.7.so
> > 7f77e0926000-7f77e0965000 r--p 00000000 08:03 6521179
> > /usr/lib/locale/en_GB.utf8/LC_CTYPE
> > 7f77e0965000-7f77e0969000 rw-p 7f77e0965000 00:00 0
> > 7f77e0982000-7f77e0983000 r--p 00000000 08:03 6521188
> > /usr/lib/locale/en_GB.utf8/LC_MESSAGES/SYS_LC_MESSAGES
> > 7f77e0983000-7f77e098a000 r--s 00000000 08:03 6496774
> > /usr/lib/gconv/gconv-modules.cache
> > 7f77e098a000-7f77e098d000 rw-p 7f77e098a000 00:00 0
> > 7f77e098d000-7f77e098f000 rw-p 0001d000 08:03 6676548 /lib/ld-2.7.so
> > 7fffe8979000-7fffe898e000 rw-p 7ffffffea000 00:00 0 [stack]
> > 7fffe89fe000-7fffe8a00000 r-xp 7fffe89fe000 00:00 0 [vdso]
> > ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
> > Aborted
> >>>> Hi list!
> >>>> I just finish first version of new grass module r.stream. Module is
> >>>> regular
> >>>> Grass module, written in C an has no addational dependencies. It was
> >>>> compiled with GRASS65 devel  downloaded in last  two week. Source code
> >>>> you
> >>>> can find here:
> >>>> http://heretic.livenet.pl/heretic/r.stream.tar.gz
> >>>> Module compiles and seems to work. Analysis was tested only on one
> >>>> dataset.
> >>>> To compile it copy r.streams directory to your grassXX../raster/  cd
> >>>> r.stream run make and make install
> >>>> What module calculate:
> >>>> - strahler stream order
> >>>> - shreeve stream magnitude
> >>>> - class of topological elements of drainage networks
> >>>> Module use r.watershed outputs: SDF flow direction and SDF stream
> >>>> network.
> >>>> Analysis of r.stream shall be run on same regions setings as
> >>>> r.watershed. If
> >>>> no, run g.region rast=your_dir_file first. For now module do not check
> >>>> if
> >>>> region and rasters are identical. It is planned to add in nearest
> >>>> feature.
> >>>> It also do not check if dirs and streams are SDF result. Threre are no
> >>>> addational description. It will be added after testing.
> >>>> It works only on cells data. Floating points data are not allowed (and
> >>>> have
> >>>> no sense).
> >>>> Module is quite fast. 3000 x3000 cells all three analysis runs no more
> >>>> than
> >>>> 30 s. on AMD 3800 2GB, Ubuntu 8.04
> >>>> Module is part of comprehensive project which will add full Horton
> >>>> analysis
> >>>> and some addational terrrains analysis to Grass. More details in the
> >>>> feature. Any cooperation is welcome. The next module I plan is
> >>>> directional
> >>>> vectorisation of stream network.
> >>>> For now module is available only form web address pointed below. After
> >>>> testing and removing critical errors it will be added to grass add-ons
> >>>> (or
> >>>> maybe to main branch?).
> >>>> Any coments, improvements and critics is very welcome.
> >>>> More advanced Grass developers: Please check my code. Its funny, but I
> >>>> don't
> >>>> know C.
> >>>> General code is based on GRASS r.topindex module (by Keith Beven and
> >>>> Huidae
> >>>> Cho, strongly modified)
> >>>> Strahler stream order algorithm from Saga GIS (by Victor Olaya,
> >>>> modified)
> >>>> Shreeve stream magnitude and class of topological network are my own
> >>>> ideas
> >>>> Test and enjoy.
> >>>> Jarek Jasiewicz
> >>>> Adam Mickiewicz University, Poznan
> >>>> Geoecology and Geoinformation Institute
> >>>> _______________________________________________
> >>>> grass-user mailing list
> >>>> grass-user at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> > Eng. Margherita Di Leo
> > Ph.D. Student Methods and Technologies for Environmental Monitoring
> > Department of Environmental Engineering and Physics (DIFA)
> > University of Basilicata Campus Macchia Romana
> > 85100 - Potenza Italy
> > Office: +39-0971205363
> > Fax: +39-0971205160
> > E-mail: dileomargherita AT gmail DOT com
> > Skype: dileomargherita
> > URL:
> http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods.  We are mammals, and have not exhausted the
> annoying little problems of being mammals.
>        -K. Mullis
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090728/ae104070/attachment-0001.html
