[GRASS-user] Re: announcement of strahler stream order analysis
Annalisa Minelli
annagrass6 at gmail.com
Tue Jul 28 09:34:19 EDT 2009
2009/7/28 Annalisa Minelli <annagrass6 at gmail.com>
> I tried it just right now to see the strahler ordering and.. it works
> greatly!
> well done Jarek..:-)
> I think I'm going to read the code because I've got to understand how did
> you solved the problem of cleaning topology..
oops.. forgive me.. you didn't use v.strahler so you don't pass through
vector format..
good idea!
> congratulations! great work!!!
> Annalisa
> 2009/7/28 stephen sefick <ssefick at gmail.com>
> It works fine on my machine. Mac OS X, compilied addon and compilied
>> GRASS from scratch. The strahler output also looks sensable. I do
>> have a question, though. Say I have my own delineated streams with
>> another method, but in raster format- will this still work? And is
>> there an easy way to a vector out of a raster stream network?
>> Stephen Sefick
>> On Tue, Jul 28, 2009 at 4:32 AM, Margherita Di Leo<diregola at gmail.com>
>> wrote:
>> > Hi Jarek,
>> > I downloaded and compiled r.stream without problems but i'm afraid it
>> does
>> > not work:
>> > r.stream dir=drainage at ex_20 stream=basin1 at ex_20 strahler=strahler
>> > shreeve=shreve class=class
>> > dirs, 3
>> > streams, 4
>> > Reading maps...
>> > *** glibc detected *** r.stream: corrupted double-linked list:
>> > 0x000000000067c2c0 ***
>> > ======= Backtrace: =========
>> > /lib/libc.so.6[0x7f77dfb86322]
>> > /lib/libc.so.6(cfree+0x8c)[0x7f77dfb89c1c]
>> > r.stream(createMaps+0x353)[0x401df3]
>> > r.stream(main+0x1c1)[0x402011]
>> > /lib/libc.so.6(__libc_start_main+0xf4)[0x7f77dfb301c4]
>> > r.stream[0x401619]
>> > ======= Memory map: ========
>> > 00400000-00404000 r-xp 00000000 08:03 5955752
>> > /usr/local/grass-6.5.svn/bin/r.stream
>> > 00603000-00604000 rw-p 00003000 08:03 5955752
>> > 00604000-41e9f000 rw-p 00604000 00:00 0 [heap]
>> > 7f77d8000000-7f77d8021000 rw-p 7f77d8000000 00:00 0
>> > 7f77d8021000-7f77dc000000 ---p 7f77d8021000 00:00 0
>> > 7f77df700000-7f77df70d000 r-xp 00000000 08:03 4071544 /lib/libgcc_s.so.1
>> > 7f77df70d000-7f77df90d000 ---p 0000d000 08:03 4071544 /lib/libgcc_s.so.1
>> > 7f77df90d000-7f77df90e000 rw-p 0000d000 08:03 4071544 /lib/libgcc_s.so.1
>> > 7f77df90e000-7f77df910000 r-xp 00000000 08:03 6677083 /lib/libdl-2.7.so
>> > 7f77df910000-7f77dfb10000 ---p 00002000 08:03 6677083 /lib/libdl-2.7.so
>> > 7f77dfb10000-7f77dfb12000 rw-p 00002000 08:03 6677083 /lib/libdl-2.7.so
>> > 7f77dfb12000-7f77dfc6a000 r-xp 00000000 08:03 6677080 /lib/libc-2.7.so
>> > 7f77dfc6a000-7f77dfe6a000 ---p 00158000 08:03 6677080 /lib/libc-2.7.so
>> > 7f77dfe6a000-7f77dfe6d000 r--p 00158000 08:03 6677080 /lib/libc-2.7.so
>> > 7f77dfe6d000-7f77dfe6f000 rw-p 0015b000 08:03 6677080 /lib/libc-2.7.so
>> > 7f77dfe6f000-7f77dfe74000 rw-p 7f77dfe6f000 00:00 0
>> > 7f77dfe74000-7f77dfef4000 r-xp 00000000 08:03 6677084 /lib/libm-2.7.so
>> > 7f77dfef4000-7f77e00f3000 ---p 00080000 08:03 6677084 /lib/libm-2.7.so
>> > 7f77e00f3000-7f77e00f5000 rw-p 0007f000 08:03 6677084 /lib/libm-2.7.so
>> > 7f77e00f5000-7f77e010b000 r-xp 00000000 08:03 6490242
>> > /usr/lib/libz.so.1.2.3.3
>> > 7f77e010b000-7f77e030b000 ---p 00016000 08:03 6490242
>> > 7f77e030b000-7f77e030c000 rw-p 00016000 08:03 6490242
>> > 7f77e030c000-7f77e0314000 r-xp 00000000 08:03 984193
>> > /usr/local/grass-6.5.svn/lib/libgrass_datetime.6.5.svn.so
>> > 7f77e0314000-7f77e0513000 ---p 00008000 08:03 984193
>> > 7f77e0513000-7f77e0514000 rw-p 00007000 08:03 984193
>> > 7f77e0514000-7f77e0567000 r-xp 00000000 08:03 984236
>> > /usr/local/grass-6.5.svn/lib/libgrass_gis.6.5.svn.so
>> > 7f77e0567000-7f77e0766000 ---p 00053000 08:03 984236
>> > 7f77e0766000-7f77e0769000 rw-p 00052000 08:03 984236
>> > 7f77e0769000-7f77e0770000 rw-p 7f77e0769000 00:00 0
>> > 7f77e0770000-7f77e078d000 r-xp 00000000 08:03 6676548 /lib/ld-2.7.so
>> > 7f77e0926000-7f77e0965000 r--p 00000000 08:03 6521179
>> > /usr/lib/locale/en_GB.utf8/LC_CTYPE
>> > 7f77e0965000-7f77e0969000 rw-p 7f77e0965000 00:00 0
>> > 7f77e0982000-7f77e0983000 r--p 00000000 08:03 6521188
>> > /usr/lib/locale/en_GB.utf8/LC_MESSAGES/SYS_LC_MESSAGES
>> > 7f77e0983000-7f77e098a000 r--s 00000000 08:03 6496774
>> > /usr/lib/gconv/gconv-modules.cache
>> > 7f77e098a000-7f77e098d000 rw-p 7f77e098a000 00:00 0
>> > 7f77e098d000-7f77e098f000 rw-p 0001d000 08:03 6676548 /lib/ld-2.7.so
>> > 7fffe8979000-7fffe898e000 rw-p 7ffffffea000 00:00 0 [stack]
>> > 7fffe89fe000-7fffe8a00000 r-xp 7fffe89fe000 00:00 0 [vdso]
>> > ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
>> > Aborted
>> >>>> Hi list!
>> >>>> I just finish first version of new grass module r.stream. Module is
>> >>>> regular
>> >>>> Grass module, written in C an has no addational dependencies. It was
>> >>>> compiled with GRASS65 devel downloaded in last two week. Source
>> code
>> >>>> you
>> >>>> can find here:
>> >>>> http://heretic.livenet.pl/heretic/r.stream.tar.gz
>> >>>> Module compiles and seems to work. Analysis was tested only on one
>> >>>> dataset.
>> >>>> To compile it copy r.streams directory to your grassXX../raster/ cd
>> >>>> r.stream run make and make install
>> >>>> What module calculate:
>> >>>> - strahler stream order
>> >>>> - shreeve stream magnitude
>> >>>> - class of topological elements of drainage networks
>> >>>> Module use r.watershed outputs: SDF flow direction and SDF stream
>> >>>> network.
>> >>>> Analysis of r.stream shall be run on same regions setings as
>> >>>> r.watershed. If
>> >>>> no, run g.region rast=your_dir_file first. For now module do not
>> check
>> >>>> if
>> >>>> region and rasters are identical. It is planned to add in nearest
>> >>>> feature.
>> >>>> It also do not check if dirs and streams are SDF result. Threre are
>> no
>> >>>> addational description. It will be added after testing.
>> >>>> It works only on cells data. Floating points data are not allowed
>> (and
>> >>>> have
>> >>>> no sense).
>> >>>> Module is quite fast. 3000 x3000 cells all three analysis runs no
>> more
>> >>>> than
>> >>>> 30 s. on AMD 3800 2GB, Ubuntu 8.04
>> >>>> Module is part of comprehensive project which will add full Horton
>> >>>> analysis
>> >>>> and some addational terrrains analysis to Grass. More details in the
>> >>>> feature. Any cooperation is welcome. The next module I plan is
>> >>>> directional
>> >>>> vectorisation of stream network.
>> >>>> For now module is available only form web address pointed below.
>> After
>> >>>> testing and removing critical errors it will be added to grass
>> add-ons
>> >>>> (or
>> >>>> maybe to main branch?).
>> >>>> Any coments, improvements and critics is very welcome.
>> >>>> More advanced Grass developers: Please check my code. Its funny, but
>> I
>> >>>> don't
>> >>>> know C.
>> >>>> General code is based on GRASS r.topindex module (by Keith Beven and
>> >>>> Huidae
>> >>>> Cho, strongly modified)
>> >>>> Strahler stream order algorithm from Saga GIS (by Victor Olaya,
>> >>>> modified)
>> >>>> Shreeve stream magnitude and class of topological network are my own
>> >>>> ideas
>> >>>> Test and enjoy.
>> >>>> Jarek Jasiewicz
>> >>>> Adam Mickiewicz University, Poznan
>> >>>> Geoecology and Geoinformation Institute
>> >>>> _______________________________________________
>> >>>> grass-user mailing list
>> >>>> grass-user at lists.osgeo.org
>> >>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> > Eng. Margherita Di Leo
>> > Ph.D. Student Methods and Technologies for Environmental Monitoring
>> > Department of Environmental Engineering and Physics (DIFA)
>> > University of Basilicata Campus Macchia Romana
>> > 85100 - Potenza Italy
>> > Office: +39-0971205363
>> > Fax: +39-0971205160
>> > E-mail: dileomargherita AT gmail DOT com
>> > Skype: dileomargherita
>> > URL:
>> http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
>> Stephen Sefick
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods. We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>> -K. Mullis
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090728/0d90afbf/attachment.html
