[GRASS-user] error: Incompatible library version for module.
You need to rebuild GRASS or untangle multiple installations.
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Jul 28 23:35:06 EDT 2009
On Tue, 2009-07-28 at 22:06 -0500, stephen sefick wrote:
> WOW! I don't have a clue. That is nowhere close to the problem that
> I had. Sorry if I am asking obvious, or redundant questions. Are you
> installing within R, or from the commandline (R CMD install)?
>From within R with root access (e.g. sudo R, then the rest).
> I will
> help if I can, but I think this may be over my paygrade.
> good luck!
Thanks for your concern Stephen.
Kind regards, Nikos
