[GRASS-user] error: Incompatible library version for module. You
	need to rebuild GRASS or untangle multiple installations.
    stephen sefick
    ssefick at gmail.com
    Tue Jul 28 23:06:04 EDT 2009
WOW!  I don't have a clue.  That is nowhere close to the problem that
I had.  Sorry if I am asking obvious, or redundant questions.  Are you
installing within R, or from the commandline (R CMD install)?  I will
help if I can, but I think this may be over my paygrade.
good luck!
Stephen Sefick
On Tue, Jul 28, 2009 at 9:46 PM, Nikos
Alexandris<nikos.alexandris at felis.uni-freiburg.de> wrote:
> stephen sefick wrote:
>> What computer architecture, operating system, what R version etc.?
> Right, I assume that people know that I am using Ubuntu Jaunty 64-bit, R
> 2.9.1, latest rpy2, grass-6.4.0svn from source.
>> What is the error message?
> The message is the title of this thread.
>> I am usingce 6.4RC5 GRASS and R 2.9.1 on mac
>> OS X 10.5.7, and it is working fine. I remember there being a problem
>> with something, but I don't remember exactly what.  If you were to
>> provide the error message then maybe it would jog my memory.
> Sorry, that's all the prog prints.
>> Also, it may be a good idea to search the R-sig-geo list archive, as your
>> problem may have already been solved (assuming it is the same one that
>> I had).
> Before doing countless compilations/installations I filtered the web for
> an hour! I've found some similar messages in grass-dev's mailing-list
> but nothing specific.
> I thought that /etc/ld.so.conf is my problem... and I commented out all
> grass-versions but grass-6.4.0svn. I even removed all other
> grass-versions, (re-)installed X-times spgrass6 but no luck.
> It's the first time I see this message. I also tried to do some
> debugging but R requires, I guess, special treatment (meaning other than
> gdb, etc.) !?
> Nikos
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
								-K. Mullis
