[GRASS-user] error: Incompatible library version for module. You
need to rebuild GRASS or untangle multiple installations.
Maris Nartiss
maris.gis at gmail.com
Wed Jul 29 04:43:32 EDT 2009
In two words - You are running module compiled for different GRASS
version than one You are running. Recompile affected module OR, if You
have multiple GRASS installations, fix Your LD_LIBRARY_PATH paths.
Maris.
2009/7/29, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
> Hi dev's and advanced useRs,
> I have seen this message for the X-th time now :-( while trying to load
> (anything) data using readRAST6 or readVECT6.
> I've rebuild grass-6.4.0svn 2-3 times now. I've re-installed R 2-3 times
> as well. Not to mention how many attempts to get "spgrass6".
> Which is the "incompatible library" and to which "module" does it refer
> to? Is this an R error or a grass error? Any help is *higly*
> appreciated.
> Kind regards, Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
