[GRASS-user] Reprojecting and resampling raster map (base
modeling)
stephen sefick
ssefick at gmail.com
Thu Jul 30 15:38:07 EDT 2009
One more thing, I am trying to predict long-term average base flow
from baseflow index, runoff, and flow accumulation (from r.terraflow),
Any help would be great.
Stephen Sefick
On Thu, Jul 30, 2009 at 2:25 PM, stephen sefick<ssefick at gmail.com> wrote:
> a resolution of 50 in UTM would translate to 2500 sqm for the area of
> a grid cell? Is there any way to preform a weighted flow
> accumulation?
> thanks,
> Stephen Sefick
> On Thu, Jul 30, 2009 at 1:51 PM, Nikos
> Alexandris<nikos.alexandris at felis.uni-freiburg.de> wrote:
>> stephen sefick wrote:
>>> When you reproject a raster map to a new location does it
>>> automatically re-sample it to the regions resolution. I have a 10x10
>>> meter grid in albers equal area projection. I have reprojected it
>>> into UTM zone 17 res=50. This is a base flow index map bfi. Does
>>> grass resample the map to 50x50m?
>> Yes, given that the _target_ location is of res=50. You can, however,
>> control this by changing the resolution (g.region) or directly at the
>> reprojection process by setting the "resolution=" parameter of the
>> "r.proj" module. You can even set the resampling algorithm (default
>> nearest neighbour or bilinear).
>> Hope this is what you've been looking for.
>> Nikos
>>> The problem is this:
>>> I have an average runoff value (arv) in m/s (converted from mm/day
>>> into m/s by dividing by 86,400s*1000mm).
>>> flow accumulation grid produced by r.terraflow (which was 30x30m
>>> resampled to 50x50m).
>>> flow accumulation * 250 (to get square meters (50x50))
>>> bfi*arv*flow accumulation (sqm)
>>> to get discharge in cms
>>> I converted this to cfs (multiplied by 35.314454)
>>> the resulting map is discharge in cfs
>>> The estimate for discharge is ~3x what the long term average is at
>>> usgs gauging stations along the rivers of interest (point layer to
>>> identify where they are located). The only thing that I have been
>>> able to think of at this point is that there is a resampling step I am
>>> missing because 10x10=100 and 50x50=250. which would account for
>>> almost the 3x discrepancy.
>>> If you need anymore information please don't hesitate to ask. I
>>> appreciate any and all help.
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
Stephen Sefick
-K. Mullis
