[GRASS-user] r.thin quirk
Dwight Needels
needels at translucida.com
Sat Jun 6 23:36:45 EDT 2009
Hi all. I have run into a quirk using r.thin, but I am not sure
whether or not it is a bug. I have a raster that was generated from
multiple GPS tracks using v.rast followed by r.buffer. Using r.thin
followed by r.to.vect creates a vector that must then be cleaned using
v.clean to remove dangles (so far, so good).
The quirk is that r.thin occasionally creates a triangle at the
intersection of two lines instead of two intersecting lines. All of
the examples I have seen involve relatively acute angles (less than 25
degrees??). I have attached a screenshot that shows the raster in
magenta, the vector with dangles in white, and the cleaned vector as
(a thinner) green. There are numerous acute angles that generate the
vectors I would expect, with one exception in the center.
Is this expected behavior? If so, is there an easy way to search for
all such resulting triangles in a vector or to remove all such extra
lines in a vector? If not, is there a way to fix it?
Thanks, -Dwight
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090606/3c408352/r.thin-0001.png
