[GRASS-user] r.thin quirk
    Dwight Needels
    needels at translucida.com
    Thu Jun 11 00:50:58 EDT 2009
On Jun 11, 2009, at 12:01 AM, Dwight Needels wrote:
> On Jun 6, 2009, at 11:36 PM, Dwight Needels wrote:
>> Hi all. I have run into a quirk using r.thin, but I am not sure
>> whether or not it is a bug. I have a raster that was generated from
>> multiple GPS tracks using v.rast followed by r.buffer. Using r.thin
>> followed by r.to.vect creates a vector that must then be cleaned
>> using v.clean to remove dangles (so far, so good).
>> The quirk is that r.thin occasionally creates a triangle at the
>> intersection of two lines instead of two intersecting lines. All of
>> the examples I have seen involve relatively acute angles (less than
>> 25 degrees??). I have attached a screenshot that shows the raster
>> in magenta, the vector with dangles in white, and the cleaned
>> vector as (a thinner) green. There are numerous acute angles that
>> generate the vectors I would expect, with one exception in the
>> center.
>> Is this expected behavior? If so, is there an easy way to search
>> for all such resulting triangles in a vector or to remove all such
>> extra lines in a vector? If not, is there a way to fix it?
>> Thanks, -Dwight
>> <r.thin.png>
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Although I figured out how to file a bug report on this, http://trac.osgeo.org/grass/ticket/636
> , I am not sure how to respond directly to comments on the ticket.
> Hamish, I used the screenshot showing the vectors because I had
> already created it to look for artifacts. The extra line that makes
> the triangle is also present in the thinned raster (screenshot
> attached).
> Thanks, -Dwight
> <r.thin_raster.png>
Follow-up... the two examples of this happening in this particular
file each have a single white pixel surrounded on 7 out of 8
directions by red pixels, but still touching a white pixel on a corner
in the 8th direction (see two screenshots). I suspect that r.thin is
treating this as a hole even though it is touching an edge. Another
way of saying this is that the two red pixels touching in 1 out of the
8 directions are treated as a line.
Perhaps there could be a flag to control this behavior.
Thanks, -Dwight
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090611/758b6aa6/r.thinpinched_1-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090611/758b6aa6/r.thinpinched_2-0001.png
