[GRASS-user] r.out.vtk RGB / input issue
peter.loewe at gmx.de peter.loewe at gmx.de
Wed Jun 17 09:18:23 EDT 2009
hi,
i am using v.out.vtk on grass6.3 on suse.
trying to export 2.5d rgb-maps to paraview using r.out.vtk always ends up with an error message:
According to the module's manual it should be possible to export a RGBmap + dem by using the parameters
rgbmaps=redmap,bluemap,greenmap elevation=my_dem output=result.vtk
However, the module reports that the INPUT parameter has to be provided.
trying
input=rgbmap rgbmaps=redmap,bluemap,greenmap elevation=my_dem output=result.vtk
results in the same as
input=rgbmap elevation=my_dem output=result.vtk
In both cases "result.vtk" is displayed with interpolated false colors.
How can a RGB composite created in GRASS properly be transferred and displayed in Paraview ?
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und Telefonanschluss
für nur 17,95 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
