[GRASS-user] r.out.vtk RGB / input issue
"Sören Gebbert"
soerengebbert at gmx.de
Thu Jun 18 02:57:33 EDT 2009
i will have a look on it.
In case this is a bug, i will fix it and provide a patch.
Best regards
Soeren
-------- Original-Nachricht --------
> Datum: Wed, 17 Jun 2009 15:18:23 +0200
> Von: peter.loewe at gmx.de
> An: grass-user at lists.osgeo.org
> Betreff: [GRASS-user] r.out.vtk RGB / input issue
> hi,
> i am using v.out.vtk on grass6.3 on suse.
> trying to export 2.5d rgb-maps to paraview using r.out.vtk always ends up
> with an error message:
> According to the module's manual it should be possible to export a RGBmap
> + dem by using the parameters
> rgbmaps=redmap,bluemap,greenmap elevation=my_dem output=result.vtk
> However, the module reports that the INPUT parameter has to be provided.
> trying
> input=rgbmap rgbmaps=redmap,bluemap,greenmap elevation=my_dem
> output=result.vtk
> results in the same as
> input=rgbmap elevation=my_dem output=result.vtk
> In both cases "result.vtk" is displayed with interpolated false colors.
> How can a RGB composite created in GRASS properly be transferred and
> displayed in Paraview ?
> Peter
> Dr. Peter Löwe
> <peter.loewe at gmx.de>
> GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und Telefonanschluss
> für nur 17,95 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
