[GRASS-user] r.out.vtk RGB / input issue
"Peter Löwe"
peter.loewe at gmx.de
Thu Jun 18 03:04:05 EDT 2009
Hi Soeren,
the bug/feature is also present in 6.4RC5
Best
Peter
-------- Original-Nachricht --------
> Datum: Thu, 18 Jun 2009 08:57:33 +0200
> Von: "Sören Gebbert" <soerengebbert at gmx.de>
> An: peter.loewe at gmx.de, grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] r.out.vtk RGB / input issue
> Hi,
> i will have a look on it.
> In case this is a bug, i will fix it and provide a patch.
> Best regards
> Soeren
> > Datum: Wed, 17 Jun 2009 15:18:23 +0200
> > Von: peter.loewe at gmx.de
> > An: grass-user at lists.osgeo.org
> > Betreff: [GRASS-user] r.out.vtk RGB / input issue
> > hi,
> > i am using v.out.vtk on grass6.3 on suse.
> > trying to export 2.5d rgb-maps to paraview using r.out.vtk always ends
> up
> > with an error message:
> > According to the module's manual it should be possible to export a
> RGBmap
> > + dem by using the parameters
> > rgbmaps=redmap,bluemap,greenmap elevation=my_dem output=result.vtk
> > However, the module reports that the INPUT parameter has to be provided.
> > trying
> > input=rgbmap rgbmaps=redmap,bluemap,greenmap elevation=my_dem
> > output=result.vtk
> > results in the same as
> > input=rgbmap elevation=my_dem output=result.vtk
> > In both cases "result.vtk" is displayed with interpolated false colors.
> > How can a RGB composite created in GRASS properly be transferred and
> > displayed in Paraview ?
> > Peter
> > Dr. Peter Löwe
> > <peter.loewe at gmx.de>
> > GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und
> Telefonanschluss
> > für nur 17,95 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
Dr. Peter Löwe
