[GRASS-user] Re:
maven apache
apachemaven0 at gmail.com
Fri Jun 19 08:45:21 EDT 2009
Ah,Thanks Peter,but I am not familiar with the script without the
grass.....
2009/6/19 "Peter Löwe" <peter.loewe at gmx.net>
> Maven,
> using v.out.ogr for KML export will NOT transform your vector in geographic
> coordinates [required by GoogleEarth]. You are creating a KML-file of UTM
> coordinates instead.
> This script includes the necessary transformation step:
> http://grasslab.gisix.com/scripts/v.out.kml/
> Best,
> Peter
> Message: 7
> Date: Fri, 19 Jun 2009 10:40:20 +0800
> From: maven apache <apachemaven0 at gmail.com>
> Subject: [GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
> To: grass-user at lists.osgeo.org
> Message-ID:
> <b6ae15040906181940u733d7369tb267be73d167856d at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> This is a vector layer transfered from a raster and its general info can be
> seen as follows:
> | Layer: swi_0 at PERMANENT
> | Mapset: PERMANENT
> | Location: newlocation
> | Database: D:/GrassDataBase
> | Title:
> | Map scale: 1:1
> | Map format: native
> | Name of creator: Administrator
> | Organization:
> | Source date: Thu Jun 18 20:51:48 2009
> | Type of Map: vector (level: 2)
> | Number of points: 0 Number of areas: 88
> | Number of lines: 0 Number of islands: 79
> | Number of boundaries: 229 Number of faces: 0
> | Number of centroids: 84 Number of kernels: 0
> | Map is 3D: 0
> | Number of dblinks: 1
> | Projection: Universe Transverse Mercator (zone 0)
> | N: 2762370.84493965 S: 2668889.78644383
> | E: 636604.74247833 W: 592287.35339113
> | Digitization threshold: 0
> | Comments:
> then I want to export it to kml and add it to the google earth, I use the
> commond:
> g.region vect=swi_blue at PERMANENT
> v.out.ogr input=swi_blue at PERMANENT type=area dsn=d:/blueNew.kml layer=1
> format=KML
> and I got the errors:
> arning 1: Layer name 'swi_blue at PERMANENT' adjusted to 'swi_blue_PERMANENT'
> for XML validity.
> Exporting 4893 areas (may take some time) ...
> ERROR 1: Latitude 2764980.037140 is invalid. Valid range is [-90,90]. This
> warning will not be issued any more
> Warning 1: Longitude 638073.992861 has been modified to fit into range
> [-180,180]. This warning will not be issued any more
> 9259 features written
> 4476 features without category written
> it seems that there is something wrong with the Coordinate,but Latitude
> 2764980.037140 is the same with the general info from the command
> v.infomap=''''''.
> I wonder it is my problem or the grass?
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20090619/4faa1346/attachment.html
> Dr. Peter Löwe
> <peter.loewe at gmx.de>
> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090619/53eee785/attachment.html
