[GRASS-user] v.lidar.edgedetection very slow
Markus GRASS
markus.metz.giswork at googlemail.com
Fri Jun 19 09:20:22 EDT 2009
Hamish wrote:
> It turns out that ~95% of the computational time is spent in the 3-deep
> nested for loops of the Tcholetsky decomposition function.
> (lidarlib/tcholDec())
> for my data it ran 16 loops of:
> 1. Bilinear interpolation
> 2. Bicubic interpolation
> 3. Point classification (fast)
> maybe these loops are another thing that could be sent out to different
> threads? (not sure if these are multiple passes or independent segments)
> Better to concentrate on the library level first? i.e. lidarlib/tcholDec()
> or is tcholDec() just written in a very inefficient way?
Some of the nested for(;;) loops could be improved by adjusting start
and end values. Maybe the attached patch for
vector/lidar/lidarlib/TcholBand.c helps. No warranty!
Markus M
Index: TcholBand.c
--- TcholBand.c (revision 37957)
+++ TcholBand.c (working copy)
@@ -9,7 +9,7 @@
void tcholDec(double **N, double **T, int n, int BW)
- int i, j, k;
+ int i, j, k, end;
double somma;
G_debug(3, "tcholDec(): n=%d BW=%d", n, BW);
@@ -18,9 +18,11 @@
G_percent(i, n, 2);
for (j = 0; j < BW; j++) {
somma = N[i][j];
- for (k = 1; k < BW; k++)
- if (((i - k) >= 0) && ((j + k) < BW))
- somma -= T[i - k][k] * T[i - k][j + k];
+ /* start = 1 */
+ /* end = BW - j or i + 1 */
+ end = ((BW - j) < (i + 1) ? (BW - j) : (i + 1));
+ for (k = 1; k < end; k++)
+ somma -= T[i - k][k] * T[i - k][j + k];
if (j == 0) {
if (somma <= 0.0)
G_fatal_error(_("Decomposition failed"));
@@ -42,7 +44,7 @@
double **T;
- int i, j;
+ int i, j, start, end;
T = G_alloc_matrix(n, BW);
@@ -54,18 +56,22 @@
parVect[0] = TN[0] / T[0][0];
for (i = 1; i < n; i++) {
parVect[i] = TN[i];
- for (j = 0; j < i; j++)
- if ((i - j) < BW)
- parVect[i] -= T[j][i - j] * parVect[j];
+ /* start = 0 or i - BW + 1 */
+ start = ((i - BW + 1) < 0 ? 0 : (i - BW + 1));
+ /* end = i */
+ for (j = start; j < i; j++)
+ parVect[i] -= T[j][i - j] * parVect[j];
parVect[i] = parVect[i] / T[i][0];
/* Backward substitution */
parVect[n - 1] = parVect[n - 1] / T[n - 1][0];
for (i = n - 2; i >= 0; i--) {
- for (j = i + 1; j < n; j++)
- if ((j - i) < BW)
- parVect[i] -= T[i][j - i] * parVect[j];
+ /* start = i + 1 */
+ /* end = n or BW + i */
+ end = (n < (BW + i) ? n : (BW + i));
+ for (j = i + 1; j < end; j++)
+ parVect[i] -= T[i][j - i] * parVect[j];
@@ -84,24 +90,28 @@
int BW)
- int i, j;
/* Forward substitution */
parVect[i] = TN[i];
- if ((i - j) < BW)
+ /* end = i */
- if ((j - i) < BW)
@@ -115,7 +125,7 @@
double **T = NULL;
double *vect = NULL;
- int i, j, k;
+ int i, j, k, start;
double somma;
@@ -136,9 +146,11 @@
invNdiag[i] = vect[0] * vect[0];
for (j = i + 1; j < n; j++) {
somma = 0.0;
- for (k = i; k < j; k++) {
- if ((j - k) < BW)
- somma -= vect[k - i] * T[k][j - k];
+ /* start = i or j - BW + 1 */
+ start = ((j - BW + 1) < i ? i : (j - BW + 1));
+ /* end = j */
+ for (k = start; k < j; k++) {
+ somma -= vect[k - i] * T[k][j - k];
vect[j - i] = somma * T[j][0];
invNdiag[i] += vect[j - i] * vect[j - i];
@@ -161,7 +173,7 @@
double **T = NULL;
- int i, j, k;
+ int i, j, k, start, end;
double somma;
@@ -175,18 +187,22 @@
parVect[i] = TN[i];
- if ((i - j) < BW)
+ /* end = i */
- if ((j - i) < BW)
@@ -201,9 +217,11 @@
somma = 0.0;
- if ((j - k) < BW)
+ /* end = j */
