[GRASS-user] Open Source GIS Meeting - Nottingham University - Monday
John Stevenson John.Stevenson at manchester.ac.uk
Sat Jun 20 07:34:01 EDT 2009
Is anyone else on the list going to this?
I'm giving a presentation in the afternoon:
 From ASCII files to orthophotos: The processing of high-
resolution aerial survey data using open source GIS software.
High quality maps are an important tool in volcanology. In August 2007
the NERC Airborne
Research and Survey Facility (ARSF) mapped the Nesjavellir region in
Iceland's Western Volcanic
Zone. LiDAR, aerial photos and multispectral infrared data were
collected with the purpose of
surveying the Nesjahraun, a lava flow that was erupted there
approximately 2000 years ago and
which exhibits complex and varied surface textures.
To allow maximum flexibility for the end user,
only low-level processing was carried out by NERC. The remaining
using open source tools, mainly GRASS, GMT, GDAL and gstat to generate
higher level products.
The command-line interface of these tools allows tight integration
with standard text- and file-
manipulation tools that are built into the GNU/Linux operating system
and lends itself easily to the
creation of scripts for the batch processing of multiple files.
The LiDAR data were provided as 6.5 Gb of ASCII text containing
information on the location and
intensity of each laser return. A preliminary DEM was prepared by
binning the data onto a 10 m
grid in GRASS. For more detailed work, the LiDAR points were
interpolated onto a 1 m grid by
kriging using the gstat software in combination with GRASS. This
high-resolution DEM was used
to orthorectify the aerial photos and multispectral infrared data by
providing both ground control
points and a topographic model. The rectified photos were formatted
for printing in GMT to
produce hard-copy maps while false-colour composite images were made
by combining different
bands of the multispectral infrared data in GRASS. GRASS was also used
to digitise roads and
other features from the orthophotos and to plot measurements made in
the field. Conversion of the
format and projection via the GDAL software allows visualisation of
much of the data in Google
EarthTM.
The article outlines the GRASS modules and other software tools used
to generate high-level
datasets from ARSF data, as a workflow template. It also demonstrates
that open source software is
a viable and cost-effective alternative to proprietary software in
analysis of GIS data.
Cheers
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson at manchester.ac.uk
