[GRASS-user] can't compile swig python on grass 7: shared no found
G. Allegri
giohappy at gmail.com
Sat Jun 20 08:36:52 EDT 2009
Hi list,
I still can't solve my compilation problem for swig python libraries
for grass 7, on kubuntu 9.04.
I receive the following error:
About the swig build I receive:
make[1]: shared: comando non trovato (command not found)
make[1]: [_utils.so] Error 127 (ignorato)
/usr/bin/install: impossibile eseguire (can't execute) stat di (of)
"_utils.so": Nessun
file o directory (No file or directory)
make[1]: *** [/home/giova/grass/grass_trunk/dist.i686-pc-linux-gnu/etc/python/grass/lib/_utils.so]
Errore 1
make: *** [default] Error 2
*Shared command not found*?! Shoudln't it be a build flag?
In the lines, before the error happens, a line appears starting with
the *shared* word, and the rest of the line contains the various LD
flags, and so on.
Is there something wrong in my build tools? I'm using the ones inside
the build-essential package [1]
Thanks,
Giovanni
[1] http://packages.ubuntu.com/jaunty/build-essential
