[GRASS-user] can't compile swig python on grass 7: shared no found
Martin Landa landa.martin at gmail.com
Sat Jun 20 08:41:28 EDT 2009
2009/6/20 G. Allegri <giohappy at gmail.com>:
> make[1]: shared: comando non trovato (command not found)
> make[1]: [_utils.so] Error 127 (ignorato)
> /usr/bin/install: impossibile eseguire (can't execute) stat di (of)
> "_utils.so": Nessun
> file o directory (No file or directory)
> make[1]: *** [/home/giova/grass/grass_trunk/dist.i686-pc-linux-gnu/etc/python/grass/lib/_utils.so]
> Errore 1
> make: *** [default] Error 2
> *Shared command not found*?! Shoudln't it be a build flag?
> In the lines, before the error happens, a line appears starting with
> the *shared* word, and the rest of the line contains the various LD
> flags, and so on.
> Is there something wrong in my build tools? I'm using the ones inside
> the build-essential package [1]
Probably, the variable for C compiler is empty, see include/Make/Compile.make
-> compiler_c
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
