[GRASS-user] Ratioing and pan-sharpening
Knut Arne Bjørndal bob+osm at cakebox.net
Sun Jun 21 11:43:49 EDT 2009
Hi
I'm trying to create a base layer for a topo map using a DEM and
landsat data.
To make sure everything isn't simply a smear of colors I use ratioing
of the landsat bands so that I can draw with a couple of different
colors. I currently use 4-3/4+3 (ndvi) and 5-6/5+6.
Now I would like to pan-sharpen to improve the resolution of the
finished product, and I'm wondering what the best way to do this is.
First: Do I pan-sharpen the original band data before ratioing, or do
I sharpen the ratio output somehow?
Second: What's the best way to pan-sharpen this? Most examples I could
find talked a lot about getting a natural-looking rgb image, which
isn't what I want.
I tried i.fusion.brovey, and sharpened bands 3, 4 and 5 and then tried
ratioing based on that but the output was very different (in a worse
way) than the normal NDVI.
Then I tried a receipe from "Open Source GIS" which translated the
image to HIS and back again with band 80 as intensity, this seems to
have helped the resolution of the 5/6 ratio, but not the 4/3. I did
the sharpening using red=band30 green=band40 blue=band50.
Oh, and is it possible to pan-sharpen band 6 data too?
PS: I'd appreciate copies of replies directly to me in addition to to
the list since I often don't have the time to read the list.
Knut Arne Bjørndal
aka Bob Kåre
bobkare at irc
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090621/4e368740/smime.bin
