[GRASS-user] can't compile swig python on grass 7: shared no found
G. Allegri giohappy at gmail.com
Mon Jun 22 06:29:45 EDT 2009
Ok, the update solved every error.
thx,
giovanni
2009/6/22 Glynn Clements <glynn at gclements.plus.com>:
> G. Allegri wrote:
>> > Python modules are linked using $(CXX); I'm guessing this is empty,
>> > probably due to --with-cxx not being used.
>> Ok, I've added --with-cxx.
>> Now I get the following:
>> In file included from proj_wrap.c:2694:
>> /home/giova/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass/gprojects.h:23:29:
>> error: ogr_srs_api.h: Nessun file o directory
> Are you using the most recent version of the GRASS source code? I
> believe this has been fixed within the last couple of days.
> Also, you should use e.g.
>        LC_ALL=C make
> if you intend to post error messages to the list.
