[GRASS-user] row() and col() problem
Hamish
hamish_b at yahoo.com
Tue Jun 23 03:43:30 EDT 2009
Jarosław Jasiewicz wrote:
> I try to generate map where every cell will have unique value
> I do that with following mapcalc formula:
> map=(row()*451)+col()
> where 451 is the total number of columns + 1
> I expected following solution;
> 452,453,454,455,....
> 953,954,955,956,....
> But I recived:
> 452,452,453,454,454,....
> Where is the error in formula (or it is rounding problem)?
did you change the g.region resolution after creating the map?
if you do 'g.region rast=map' before output is it ok?
Hamish
