[GRASS-user] row() and col() problem
Jarosław Jasiewicz jarekj at amu.edu.pl
Tue Jun 23 05:50:34 EDT 2009
Hamish pisze:
> Jarosław Jasiewicz wrote:
>> I try to generate map where every cell will have unique value
>> I do that with following mapcalc formula:
>> map=(row()*451)+col()
>> where 451 is the total number of columns + 1
>> I expected following solution;
>> 452,453,454,455,....
>> 953,954,955,956,....
>> But I recived:
>> 452,452,453,454,454,....
>> Where is the error in formula (or it is rounding problem)?
> did you change the g.region resolution after creating the map?
> if you do  'g.region rast=map' before output is it ok?
Yes, but not
> Hamish
well, the problem may lays elsewhere
r.stats -1 input=map shows expected result, but when I use "display cell
values layer" form gis.m it shows wrong results. It change default
region as I know.
thanks
Jarek
