[GRASS-user] qgis + grass-plugin = gdal-problem (update)
achim
ak7 at jupiter.uni-freiburg.de
Mon Mar 2 04:45:00 EST 2009
thanks for answering and sorry for taking so long..
Im running suse 11.1 and I was installing both qgis and grass from the
following repositories:
http://teodori.org/repos/grass/openSuSE11.1/
and
http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
As said deinstalling the old and reinstalling of the packages via yast
does not help. Now I'm using only grass, but I would really like to use
the comfortable qgis in future too.
Thanks,
achim
Zahid Parvez schrieb:
> > On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
> > <nikos.alexandris at felis.uni-freiburg.de
> > <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
> > On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
> > > Hi,
> > > I used the goe-repository files for installing grass (6.4) and
> > grass63.
> > > Do I have to compile myself? Cant I clean old libraries by
myself and
> > > reinstall grass from the repository?
> > > Thanks,
> > > achim
> > Hi Achim!
> > It's not clear to me which geo-repository you mean. Could you
please be
> > more specific?
> > First:
> > * Which operating system do you use?
> > * Which exact commands did you use to install grass 6.4 and which to
> > install grass 6.3?
> > * Why do you need both, version 6.3 and 6.4?
> > Now partially answering:
> > * You are not "forced" to compile grass by yourself. There are
binaries
> > ready-to-(install)use.
> > * Of course you can clean old libraries. If you installed grass from
> > ubuntu's repository for example, it should be easy to clean
everything
> > by just removing it (preferably with "sudo apt-get purge grass").
> > BTW, Jachym Cepicky's repository [1] is AFAIK always more up-to-date
> > than ubuntu's repositories.
> > Kind regards, Nikos
> > [1] http://les-ejk.cz/ubuntu/
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> > if you use windows xp sp2 this may help. i got this from internet
> > best
> > zahid
