[GRASS-user] qgis + grass-plugin = gdal-problem (update)
Otto Dassau
otto.dassau at gmx.de
Fri Mar 6 02:25:27 EST 2009
Hi Achim,
I build the opensuse packages in the Application:/Geo repository and will check
this. Do you use the 32 bit or 64 bit packages for 11.1?
regards,
Otto
On Mon, 02 Mar 2009 10:45:00 +0100
achim <ak7 at jupiter.uni-freiburg.de> wrote:
> Hi,
> thanks for answering and sorry for taking so long..
> Im running suse 11.1 and I was installing both qgis and grass from the
> following repositories:
> http://teodori.org/repos/grass/openSuSE11.1/
> and
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
> As said deinstalling the old and reinstalling of the packages via yast
> does not help. Now I'm using only grass, but I would really like to use
> the comfortable qgis in future too.
> Thanks,
> achim
> Zahid Parvez schrieb:
> > > On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
> > > <nikos.alexandris at felis.uni-freiburg.de
> > > <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
> > > On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
> > > > Hi,
> > > > I used the goe-repository files for installing grass (6.4) and
> > > grass63.
> > > > Do I have to compile myself? Cant I clean old libraries by
> myself and
> > > > reinstall grass from the repository?
> > > > Thanks,
> > > > achim
> > > Hi Achim!
> > > It's not clear to me which geo-repository you mean. Could you
> please be
> > > more specific?
> > > First:
> > > * Which operating system do you use?
> > > * Which exact commands did you use to install grass 6.4 and which to
> > > install grass 6.3?
> > > * Why do you need both, version 6.3 and 6.4?
> > > Now partially answering:
> > > * You are not "forced" to compile grass by yourself. There are
> binaries
> > > ready-to-(install)use.
> > > * Of course you can clean old libraries. If you installed grass from
> > > ubuntu's repository for example, it should be easy to clean
> everything
> > > by just removing it (preferably with "sudo apt-get purge grass").
> > > BTW, Jachym Cepicky's repository [1] is AFAIK always more up-to-date
> > > than ubuntu's repositories.
> > > Kind regards, Nikos
> > > [1] http://les-ejk.cz/ubuntu/
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > > if you use windows xp sp2 this may help. i got this from internet
> > > best
> > > zahid
