[GRASS-user] qgis + grass-plugin = gdal-problem (update)
achim
ak7 at jupiter.uni-freiburg.de
Fri Mar 6 03:57:57 EST 2009
I use a 64 bit system and 64 bit packages (for suse 11.1)
achim
Otto Dassau schrieb:
> Hi Achim,
> I build the opensuse packages in the Application:/Geo repository and will check
> this. Do you use the 32 bit or 64 bit packages for 11.1?
> regards,
> Otto
> On Mon, 02 Mar 2009 10:45:00 +0100
> achim <ak7 at jupiter.uni-freiburg.de> wrote:
>> Hi,
>> thanks for answering and sorry for taking so long..
>> Im running suse 11.1 and I was installing both qgis and grass from the
>> following repositories:
>> http://teodori.org/repos/grass/openSuSE11.1/
>> and
>> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
>> As said deinstalling the old and reinstalling of the packages via yast
>> does not help. Now I'm using only grass, but I would really like to use
>> the comfortable qgis in future too.
>> Thanks,
>> achim
>> Zahid Parvez schrieb:
>>>> On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
>>>> <nikos.alexandris at felis.uni-freiburg.de
>>>> <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
>>>> On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
>>>> > Hi,
>>>> > I used the goe-repository files for installing grass (6.4) and
>>>> grass63.
>>>> > Do I have to compile myself? Cant I clean old libraries by
>> myself and
>>>> > reinstall grass from the repository?
>>>> > Thanks,
>>>> > achim
>>>> Hi Achim!
>>>> It's not clear to me which geo-repository you mean. Could you
>> please be
>>>> more specific?
>>>> First:
>>>> * Which operating system do you use?
>>>> * Which exact commands did you use to install grass 6.4 and which to
>>>> install grass 6.3?
>>>> * Why do you need both, version 6.3 and 6.4?
>>>> Now partially answering:
>>>> * You are not "forced" to compile grass by yourself. There are
>> binaries
>>>> ready-to-(install)use.
>>>> * Of course you can clean old libraries. If you installed grass from
>>>> ubuntu's repository for example, it should be easy to clean
>> everything
>>>> by just removing it (preferably with "sudo apt-get purge grass").
>>>> BTW, Jachym Cepicky's repository [1] is AFAIK always more up-to-date
>>>> than ubuntu's repositories.
>>>> Kind regards, Nikos
>>>> [1] http://les-ejk.cz/ubuntu/
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>> if you use windows xp sp2 this may help. i got this from internet
>>>> best
>>>> zahid
