[GRASS-user] importing an e00 file grass6.2
Janet Choate
jsc.eco at gmail.com
Wed Mar 4 12:18:18 EST 2009
Hello grass user community,
I am trying to import an e00 file into grass6.2.2. In older versions of
grass, I was able to use m.in.e00, which is no longer available with grass6
versions. I see that I should be able to use v.in.e00 with grass6.2.2.
However, I get the following error:
command used: v.in.e00 file=ms02714.e00 type=area
An error may appear next which will be ignored...
E00 Compressed ASCII found. Will uncompress first...
...converted to Arc Coverage in current directory
Importing areas...
Cannot open data source: ms02714
An error occurred. Stop.
Any advice about another way to import or any pre processing on this would
be appreciated.
thanx,
Janet
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090304/b4ba9f20/attachment.html
