[GRASS-user] importing an e00 file grass6.2
Markus Neteler
neteler at osgeo.org
Wed Mar 4 16:46:49 EST 2009
On Wed, Mar 4, 2009 at 6:18 PM, Janet Choate <jsc.eco at gmail.com> wrote:
> Hello grass user community,
> I am trying to import an e00 file into grass6.2.2. In older versions of
> grass, I was able to use m.in.e00, which is no longer available with grass6
> versions. I see that I should be able to use v.in.e00 with grass6.2.2.
> However, I get the following error:
> command used: v.in.e00 file=ms02714.e00 type=area
> An error may appear next which will be ignored...
> E00 Compressed ASCII found. Will uncompress first...
> ...converted to Arc Coverage in current directory
> Importing areas...
> Cannot open data source: ms02714
> An error occurred. Stop.
If possible, send the file to me and I'll give it a try.
> Any advice about another way to import or any pre processing on this would
> be appreciated.
Otherwise please consider to update to 6.4.0RC3 which is pretty
stable already. It should work (or we have to fix a bug).
Markus
