[GRASS-user] qgis + grass-plugin = gdal-problem (update)
Otto Dassau
otto.dassau at gmx.de
Mon Mar 9 16:37:08 EDT 2009
On Sat, 7 Mar 2009 19:31:09 +0100
Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi Achim,
> On Sat, 07 Mar 2009 19:26:59 +0100
> achim <ak7 at jupiter.uni-freiburg.de> wrote:
> > Hi Otto,
> > have you find out, what the problem could be? I am still willing to use
> > grass with qgis, but -as written- qgis terminates when loading a raster
> > file from a grass project. I tried an older qgis version, but the error
> > is the same:
> > qgis: symbol lookup error: /usr/lib/gdalplugins/gdal_GRASS.so: undefined
> > symbol: G_no_gisinit
> > I'm afraid I made something wrong with my openSUSE 11.1 64bit...
> > Sorry for being so impatient,
> I haven't had the time to look at it yet. I will test as soon as possible, but
> it will probably take some more days. I am very busy at the moment - sorry.
I updated the packages gdal,grass,gdal-grass,qgis and it should work now -
please test and report.
regards,
Otto
> regards,
> Otto
> > achim
> > achim schrieb:
> > > I use a 64 bit system and 64 bit packages (for suse 11.1)
> > > achim
> > > Otto Dassau schrieb:
> > >> Hi Achim,
> > >> I build the opensuse packages in the Application:/Geo repository and will
> check
> > >> this. Do you use the 32 bit or 64 bit packages for 11.1?
> > >> regards,
> > >> Otto
> > >> On Mon, 02 Mar 2009 10:45:00 +0100
> > >>> Hi,
> > >>> thanks for answering and sorry for taking so long..
> > >>> Im running suse 11.1 and I was installing both qgis and grass from the
> > >>> following repositories:
> > >>> http://teodori.org/repos/grass/openSuSE11.1/
> > >>> and
http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
> > >>> As said deinstalling the old and reinstalling of the packages via yast
> > >>> does not help. Now I'm using only grass, but I would really like to use
> > >>> the comfortable qgis in future too.
> > >>> Thanks,
> > >>> achim
> > >>> Zahid Parvez schrieb:
> > >>>>> On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
> > >>>>> <nikos.alexandris at felis.uni-freiburg.de
> > >>>>> <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
> > >>>>> On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
> > >>>>> > Hi,
> > >>>>> > I used the goe-repository files for installing grass (6.4) and
> > >>>>> grass63.
> > >>>>> > Do I have to compile myself? Cant I clean old libraries by
> > >>> myself and
> > >>>>> > reinstall grass from the repository?
> > >>>>> > Thanks,
> > >>>>> > achim
> > >>>>> Hi Achim!
> > >>>>> It's not clear to me which geo-repository you mean. Could you
> > >>> please be
> > >>>>> more specific?
> > >>>>> First:
> > >>>>> * Which operating system do you use?
> > >>>>> * Which exact commands did you use to install grass 6.4 and which
to
> > >>>>> install grass 6.3?
> > >>>>> * Why do you need both, version 6.3 and 6.4?
> > >>>>> Now partially answering:
> > >>>>> * You are not "forced" to compile grass by yourself. There are
> > >>> binaries
> > >>>>> ready-to-(install)use.
> > >>>>> * Of course you can clean old libraries. If you installed grass
from
> > >>>>> ubuntu's repository for example, it should be easy to clean
> > >>> everything
> > >>>>> by just removing it (preferably with "sudo apt-get purge grass").
> > >>>>> BTW, Jachym Cepicky's repository [1] is AFAIK always more
up-to-date
> > >>>>> than ubuntu's repositories.
> > >>>>> Kind regards, Nikos
> > >>>>> [1] http://les-ejk.cz/ubuntu/
> > >>>>> _______________________________________________
> > >>>>> grass-user mailing list
> > >>>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> > >>>>> if you use windows xp sp2 this may help. i got this from internet
> > >>>>> best
> > >>>>> zahid
