[GRASS-user] qgis + grass-plugin = gdal-problem (update)
achim
ak7 at jupiter.uni-freiburg.de
Tue Mar 10 09:23:34 EDT 2009
Great! Now it works.
Thank you Otto for effort.
...but...to handle raster files is pretty slow in QGIS!
My Windows-Qgis works faster and not-grass-mapset-maps are handled fine
as well.
Any thoughts?
achim
(Sooner or later I get following message:
Warning: QPainter::end: Painter not active, aborted
Warning: QPainter::begin: Cannot paint on a null pixmap
Warning: QPainter::setFont: Painter not active
Warning: QPixmap::scaled: Pixmap is a null pixmap)
Otto Dassau schrieb:
> On Sat, 7 Mar 2009 19:31:09 +0100
> Otto Dassau <otto.dassau at gmx.de> wrote:
>> Hi Achim,
>> On Sat, 07 Mar 2009 19:26:59 +0100
>> achim <ak7 at jupiter.uni-freiburg.de> wrote:
>>> Hi Otto,
>>> have you find out, what the problem could be? I am still willing to use
>>> grass with qgis, but -as written- qgis terminates when loading a raster
>>> file from a grass project. I tried an older qgis version, but the error
>>> is the same:
>>> qgis: symbol lookup error: /usr/lib/gdalplugins/gdal_GRASS.so: undefined
>>> symbol: G_no_gisinit
>>> I'm afraid I made something wrong with my openSUSE 11.1 64bit...
>>> Sorry for being so impatient,
>> I haven't had the time to look at it yet. I will test as soon as possible, but
>> it will probably take some more days. I am very busy at the moment - sorry.
> I updated the packages gdal,grass,gdal-grass,qgis and it should work now -
> please test and report.
> regards,
> Otto
>> regards,
>> Otto
>>> achim
>>> achim schrieb:
>>>> I use a 64 bit system and 64 bit packages (for suse 11.1)
>>>> achim
>>>>> Hi Achim,
>>>>> I build the opensuse packages in the Application:/Geo repository and will
>> check
>>>>> this. Do you use the 32 bit or 64 bit packages for 11.1?
>>>>> regards,
>>>>> Otto
>>>>> On Mon, 02 Mar 2009 10:45:00 +0100
>>>>>> Hi,
>>>>>> thanks for answering and sorry for taking so long..
>>>>>> Im running suse 11.1 and I was installing both qgis and grass from the
>>>>>> following repositories:
>>>>>> http://teodori.org/repos/grass/openSuSE11.1/
>>>>>> and
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_11.1/
>>>>>> As said deinstalling the old and reinstalling of the packages via yast
>>>>>> does not help. Now I'm using only grass, but I would really like to use
>>>>>> the comfortable qgis in future too.
>>>>>> Thanks,
>>>>>> achim
>>>>>> Zahid Parvez schrieb:
>>>>>>>> On Sat, Feb 28, 2009 at 9:09 AM, Nikos Alexandris
>>>>>>>> <nikos.alexandris at felis.uni-freiburg.de
>>>>>>>> <mailto:nikos.alexandris at felis.uni-freiburg.de>> wrote:
>>>>>>>> On Fri, 2009-02-27 at 13:39 +0100, achim wrote:
>>>>>>>> > Hi,
>>>>>>>> > I used the goe-repository files for installing grass (6.4) and
>>>>>>>> grass63.
>>>>>>>> > Do I have to compile myself? Cant I clean old libraries by
>>>>>> myself and
>>>>>>>> > reinstall grass from the repository?
>>>>>>>> > Thanks,
>>>>>>>> > achim
>>>>>>>> Hi Achim!
>>>>>>>> It's not clear to me which geo-repository you mean. Could you
>>>>>> please be
>>>>>>>> more specific?
>>>>>>>> First:
>>>>>>>> * Which operating system do you use?
>>>>>>>> * Which exact commands did you use to install grass 6.4 and which
> to
>>>>>>>> install grass 6.3?
>>>>>>>> * Why do you need both, version 6.3 and 6.4?
>>>>>>>> Now partially answering:
>>>>>>>> * You are not "forced" to compile grass by yourself. There are
>>>>>> binaries
>>>>>>>> ready-to-(install)use.
>>>>>>>> * Of course you can clean old libraries. If you installed grass
> from
>>>>>>>> ubuntu's repository for example, it should be easy to clean
>>>>>> everything
>>>>>>>> by just removing it (preferably with "sudo apt-get purge grass").
>>>>>>>> BTW, Jachym Cepicky's repository [1] is AFAIK always more
> up-to-date
>>>>>>>> than ubuntu's repositories.
>>>>>>>> Kind regards, Nikos
>>>>>>>> [1] http://les-ejk.cz/ubuntu/
>>>>>>>> _______________________________________________
>>>>>>>> grass-user mailing list
>>>>>>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>>>> if you use windows xp sp2 this may help. i got this from internet
>>>>>>>> best
>>>>>>>> zahid
