[GRASS-user] Some question about r.in.xyz and r.surf.idw
    Jhon Ortiz
    eljhonjhon at hotmail.com
    Mon Mar  9 19:31:22 EDT 2009
Hi all,
Im working with xyz data, the range of my data is:    min = 0.046000  max = 1.358000
And  I'm trying interpolate with r.surf.idw, but the answer is  "Range of data:    min = 1  max = 1"
I'm working with these steps:
r.in.xyz input="biomarcadores.txt" output="r_bio" method="mean" type="FCELL" fs="|" x=2 y=1 z=4 zscale=1.0  percent=100
r.surf.idw input=r_bio output=r_sup_bio
The problem is when I try work with decimal numbers.
some advice about how I'll work with decimal numbers in this process?
Thanks for your help!!
John
Grupo Bioestratigrafia - ICP
Bogotá - Colombia
_________________________________________________________________
¿Quieres ver los mejores videos de MSN? Enciende Messenger TV
http://messengertv.msn.com/mkt/es-es/default.htm
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090310/a4782f56/attachment.html
