[GRASS-user] Some question about r.in.xyz and r.surf.idw
Alberto Pettazzi
alberto.pettazzi at meteogalicia.es
Tue Mar 10 03:31:59 EDT 2009
Hi John,
I had the same problem. As Hamish told me some weeks ago,
"r.surf.idw and r.surf.idw2 only produce CELL (integer) maps."
I solved my problem multiplying the input raster by 100 (r_bio in your case), then I interpolated with r.surf.idw and finally divided once again by 100.
Hope this may help you
Alberto Pettazzi
MeteoGalicia - Departamento de Climatología y Observación
Consellería de Medio Ambiente e Desenvolvemento Sostible
Rúa de Roma, 6
15707 Santiago de Compostela. A Coruña
Teléfono: +34-881-999646
e-mail: alberto.pettazzi at meteogalicia.es
<mailto:alberto.pettazzi at meteogalicia.es>
Jhon Ortiz escribió:
> Hi all,
> Im working with xyz data, the range of my data is: min = 0.046000
> max = 1.358000
> And I'm trying interpolate with r.surf.idw, but the answer is "Range
> of data: min = 1 max = 1"
> I'm working with these steps:
> r.in.xyz input="biomarcadores.txt" output="r_bio" method="mean"
> type="FCELL" fs="|" x=2 y=1 z=4 zscale=1.0 percent=100
> r.surf.idw input=r_bio output=r_sup_bio
> The problem is when I try work with decimal numbers.
> some advice about how I'll work with decimal numbers in this process?
> Thanks for your help!!
> John
> Grupo Bioestratigrafia - ICP
> Bogotá - Colombia
> Comparte tus fotos con tus amigos. Más fácil con Windows Live
> <http://download.live.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
