[GRASS-stats] Re: [GRASS-user] Testing i.pca ~ prcomp(),
m.eigensystem ~ princomp()
Hamish
hamish_b at yahoo.com
Thu Mar 12 03:26:26 EDT 2009
Nikos:
> > http://grass.osgeo.org/wiki/Principal_Component_Analysis
Roger:
> Good, thanks. There you say that you are using "some MODIS
> surface reflectance products". I guess it will be easier to
> check things if the data (GRASS location) are available, so
> that others can try the same calculations. Would it be possible
> to make one or more test sets available, and link them from thw
> Wiki?
better yet, use the standard Spearfish SPOT imagery sample dataset
for the examples. (as m.eigensystem and now i.pca help page
examples do, probably others)
is there a way to change text color in MediaWiki? it might be
easier to highlight m.eigensystem output rows by color instead
of '#'s.
idea for possible google summer of code 2009 project: overhaul i.*
modules/lib for grass7. US$4.5k bounty :)
cheers,
Hamish
