[GRASS-user] Workflow to generate full resolution composite
images
John R.
johnr at wowway.com
Fri Mar 13 23:44:30 EDT 2009
Markus Neteler wrote:
> (untested)
> Use the PNG driver and set
> export GRASS_WIDTH=xxx
> export GRASS_HEIGHT=yyy
> where xxx and yyy correspond to the raster map size.
> Then d.out.file with res=1 to save the map into PNG.
That worked...thanks!
export GRASS_WIDTH=12199
export GRASS_HEIGHT=7055
g.region rast=ra_aerial_2007.red
d.mon x0
d.rgb red=ra_aerial_2007.red green=ra_aerial_2007.green
blue=ra_aerial_2007.blue
d.vect tracks2006 type=line color=blue width=10
d.out.file tracks format=png
(defaults to resolution=1)
