[GRASS-user] Workflow to generate full resolution composite
images
Markus Neteler
neteler at osgeo.org
Thu Mar 12 16:03:09 EDT 2009
On Thu, Mar 12, 2009 at 4:03 AM, John R. <johnr at wowway.com> wrote:
> Hello,
> I have a combination of raster (rgb) and vector layers. Within the grass
> UI, I can see how to generate a png file that is at the resolution of the
> current display. However, I want to generate a image file that is at the
> full raster resolution overlaid with the vector layers.
(untested)
Use the PNG driver and set
export GRASS_WIDTH=xxx
export GRASS_HEIGHT=yyy
where xxx and yyy correspond to the raster map size.
Then d.out.file with res=1 to save the map into PNG.
Markus
> Thanks,
> John
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
