[GRASS-user] Network analysis: Linear reference system (LRS) - on
windows
Markus Neteler
neteler at osgeo.org
Fri Mar 13 03:12:59 EDT 2009
On Fri, Mar 13, 2009 at 1:36 AM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> Helmut:
>> i'm trying the example for Network analysis: Linear reference system
>> (LRS)
>> from http://www.grassbook.org/examples3rd_chapter6.php for the step
>> # add column to link the route with the bus stop
>> v.db.addtable route1 col="lid integer" (just copied from the website
>> above)
> Most likely a small mistake in the website.
No. If you look two lines above you'll see that v.category
does not copy the the table.
> Use "v.db.addcol" instead.
Please don't. It is v.db.addtable.
The example works perfectly.
I suspect an issue on Windows indeed.
Markus
PS: I have added some screenshots to
