[GRASS-user] Network analysis: Linear reference system (LRS) - on windows
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Mar 13 03:29:40 EDT 2009
On Fri, 2009-03-13 at 08:12 +0100, Markus Neteler wrote:
> On Fri, Mar 13, 2009 at 1:36 AM, Nikos Alexandris
> <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > Helmut:
> >> i'm trying the example for  Network analysis: Linear reference system
> >> (LRS)
> >> from http://www.grassbook.org/examples3rd_chapter6.php for the step
> >>  # add column to link the route with the bus stop
> >> v.db.addtable route1 col="lid integer" (just copied from the website
> >> above)
> > Most likely a small mistake in the website.
> No. If you look two lines above you'll see that v.category
> does not copy the the table.
> > Use "v.db.addcol" instead.
> Please don't. It is v.db.addtable.
> The example works perfectly.
> I suspect an issue on Windows indeed.
> Markus
> PS: I have added some screenshots to
Ahh.. :-O. Sorry, my mistake. Thanks for the clarification Markus.
