[GRASS-user] EPSG 3035
Laura Poggio
laura.poggio at gmail.com
Fri Mar 27 08:56:18 EDT 2009
Ok thanks. Maybe by hand is really the easiest solution.
Thank you
Laura
2009/3/27 Moritz Lennert <mlennert at club.worldonline.be>
> On 27/03/09 13:05, Laura Poggio wrote:
>> I will then try to upgrade the version of GRASS, but in the meantime just
>> a question.
>> All the files I will work on have the same projection as the location, at
>> least according to gdal and using EPSG codes.
>> If I create the location with the problems discussed until now and then
>> import the files with -o option, would this be source of troubles for
>> further elaborations such as watershed analysis?
> I don't think so. But you might want to try to create a "correct" location
> with all the parameters, including datum, etc. You might have to do this by
> hand though, i.e. using the option to create the location with projection
> parameters, instead of EPSG code or existing file.
> Moritz
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090327/375009fd/attachment.html
